My new to me Jet 1024P (Late 70's, taiwan) lathe has been sitting 30+ years in a heated basement workshop, my friend bought it new and never learned to use it. I think it was used a handful of times so it shouldn't be worn out. It is likely in great mechanical condition, everything looks good other than a patina and cracked paint.
There is still some old grease in the gears and everything slides smooth as butter but it seems reasonable to freshen things up a bit before I start using/learning the machine. I have read many threads on the matter and am hoping that someone can offer direct advice on what lubes I should purchase for the different parts of the machine.
My Taiwan Jet 1024P manual says all oilers should be oiled with SAE 20 oil and that all grease nipples with Keystone 122 Gear Lubricant.
An online manual, presumable for the Chinese 1024P simply says "SAE 30 oil and a Medium Grease"
Further reading tells me I want "non detergent" oils. I went on amazon and there seem to be so many different products that it is hard to distinguish them. Also some are very expensive and I don't want to overpay.
I guess what would be helpful is if someone could suggest some reasonably priced modern day product equivalents so I can get them ordered and get to work here. I figured products suggested by forum users might be a good avenue to get started.
I need grease and/or oil for the gears, leadscrew, slides, oilers.
I hear that Kerosene is good for cleaning. Any other suggest cleaning products while I'm shopping?
Thank you.
Thank you.
