If I remember right the last time it (I re-write so much it takes awhile) did it, a box to check, "delete"
Yeh, "Delete Post" section on top, then "Your Message" section, then "Additional Options". All are under the "edit post" ability, and for that you need to be logged into the account.
I do the check box, "Delete this post in the following manner", don't give a "Delete Message" 99.99% of the time (just want the double post gone) and hit the "Delete Post" button, lower right.
I know the first times I did not delete either, just checking the box and "save changes" in the "Your message" section does not delete.
