Tube coping (mitering) belt sander?
  • Tube coping (mitering) belt sander?
    I am thinking of building/converting a belt sander to use it for coping or mitering thin walled steel tubing. I picture some interchangeable sized rollers on the drive shaft end for the various cut sizes and a crowned belt tracking idler on the other end. To hold the tubes a set of "V" jaws in a vice. To position the tubing, a small (5"x5" travel) cheap X-Y vice (rebuilt so it actually works) and some sort of rotary base. The tubes are between 3/4" and 1.5" diameter and have a wall thickness between 0.016" and 0.035".
    Has anyone here ever built a belt sander or have any experience with belt tracking? I've tried making 2-1/2" dia miters on the sander drive drum as it is and it seems to work fine, not eat the belts too quickly etc. Any sage advice before I jump in?
    glenj,
    Take a look at these links. They gave me a number of ideas. Maybe it will trigger some things for you too.
    [url="http://beaumontmetalworks.com/index.html"]http://beaumontmetalworks.com/index.html[
    http://www.stephenbader.com/
    http://www.unigrinder.com/
    http://www.mstarling.com/The_Craft/T...t_grinder.html
    Allen
    [This message has been edited by ralenr (edited 05-03-2004).]
      Might be easier to just get one of these.
      http://www.harborfreight.com/cpi/cta...emnumber=42324
      For $30, it doesn't seem worth making a bunch of drums. All you need is a bi-metal hole saw for the size tubing you're cutting. These can be used with a drill or drill press (1/2").
        I got my hands on one of those belt copers that Trick tools sells and I have to say I'm hooked,it will cope ANY wall thickness tube even down to .025"
        The one I used tracked the belt on the motor drive end for obvious reasons,the motor end pulley also carried the crown,the work end roller was straight.
        Biggest think I did notice is in order to facilitate a wide range of tube sizes on a single belt length the tensioner had a large travel,about 8" as I remember,it was a piece of telescopic tubing(square)with a stout spring.
        The tracking was simply a gimble affair,picture a face mount ac motor with a 1x1" square cross section ring bolted on the front,the ring had two pins drilled in and the tracking/tensioner had a bigger ring welded in with coresponding holes in it,the motor was able to pivot about 5* side to side by means of a large wing lever.
        The work end belt rollers are a straight faced steel roller turned to a diameter to match the tubing being coped LESS the thickness of the grinding belt.The rollers had their own ball bearings(sealed)and the shaft projected through each end by about 1/2".Each end had two opposing flats milled on and the shaft simply rested in two 3/8" wide slots milled in each side of the frame,belt tension holds them in.
        It had a 6" mill vise with a swivel base and v-grooved jaws.The centerline of the v-groove was on the centerline of the belt roller.
        The vise was mounted on a set of 1" linear bearing blocks for the x travel with a lever to provide fast travel back and forth across the width of the roller/belt.The y axis was a set of rods with bronze bushings and a acme threaded leadscrew with a simple handwheel.
        It worked real nice,you just rough cut the angle on the tube with a chop saw ,set the vise angle and ground away till you hit your layout line.It used the blue Zirconia belts and a cool mist system to both control the dust and keep the belt and tube cool.
        We were mitering and copeing 2"-.095" chrome-moly tubing,a 45* saddle took about two minutes start to finish,real slick.I got to build one.
          Those drill powered tube notchers don't work on the tubing I'm using. It's very hard and very thin. Clamped in a split block of the right diameter in the vice on the mill and cut less than 1/8" from the block the cutting teeth catch and crumple the leading edge of the tube. These tubes are between C$60 and C$100 per tube so I want a solution that can reliably cut the tubes without the risk of damage involved with hole saws.
          Thanks for the links to the belt sanders. I guess I'm trying to build a smaller, less powerful version of the following.
          http://www.vansantent.com/coping_machine.htm
          Here is another setup I use in the lathe to miter the tubes. Anything over 0.025" it works just fine. These new tubes are .016" thick though.
          [This message has been edited by glenj (edited 05-04-2004).]
