I also like the idea of a peristaltic pump. Partially because it would be a fun project to make. But I think it should be manual. The diameter of the drive/pump ring will determine the volume for each degree of turn. I think the metering could be very exact once you get it primed. The thickness should maintain the prime.
Maybe you could use some little metal flip caps, like on olive oil bottles, to isolate the epoxy from air and dust (I'd make those)? Or enclose the whole thing in a nice little wall mounted box, under a cabinet.
I wonder if silicone tubing could be used, as purchased at hobby shops for fuel? Or would the residual silicone impact the performance of the epoxy? I like the way the silicone responds to squeezing by the pump roller, as compared to less flexible tubes.
