All, I am going to start the DeHaas Vault Lock 2 this weekend. The first step is to make the falling block hole. It is round, and of 1 inch diameter. The material is 4140 with a RC of 30. The hole is to be at an angle of 3-4* rearward. Using the Bridgeport, I plan to drill to 7/8, take out another .115 with the boring bar, and finish ream. The boring bar is carbide insert, the reamer is HSS. I was thinking of 220RPM for the bar, and 80RPM for the reamer with lots of cutting oil.
Where am I going to get into trouble? Do I need to mill a flat before starting a hole at this shallow angle? Thanks, Mike
