A customer has a canal Narrow Boat with an old Bolinders semi-diesel, single cylinder direct reversing 2-stroke.
He's had a problem with water getting into the cylinder and crankcase. Turned out to be the cylinder wall had corroded through from the outside.
We looked into various repair methods, but decided all would be expensive and all would carry a risk of failure.
Eventually he located a spare block. Trouble was, it had been in a fire, building burned down, 40 years ago and had been kicking around in somebody's garden ever since.
There was a major stroke of luck, in that this block had a standard bore, 190mm or about 7.5", while his existing cylinder had been bored 1.5mm oversize and had the piston to match.
I tried a flap wheel on the rusty bore in a couple of spots & decided we were in with a chance.
Took it to my friendly reconditioners, they were very doubtful but gave it a go and it did in fact clean up (honed out) very nicely at the new size.
After that it was down to me. This thing is about 170 lbs, the bore is about 19" long.
I had turned some aluminium Pie jaws to fit the bore & hold it to the lathe spindle:-
The tailstock end was supported with a rotary chuck. I was disappointed to find that mine wouldn't quite open big enough, so had to resort to using that chuck to hold another:-
This also shows the sorry state of the top joint faces, the first job was to get these back to something decent:-
More in our next...
More in our next...
