As some of you may recall, I was starting to work on a mill-drill CNC conversion. Well, the machine itself has been partially serviced, and I've collected a great deal of information, plus contacting a local DIY/CNC enthusiast.
Anyway, I'm now at the actually buying parts stage, and I'm starting with the motor. I plan on getting a motor and speed control fitted, get the pulleys and belt(s) sorted out, and the spindle rebuilt, so I can test it as a manual mill before starting the ballscrew install.
I believe I've decided to go with a DC motor and speed control, with custom pullies to give me at least two general speed ranges in addition to what the motor/speed control provides.
So, unless someone has a better source or supplier or suggestion, I'm currently looking at these motors from Surplus Center:
1) 1.5HP, 180vDC, 3100 rpm ($109.95)
2) 1.5HP, 120vDC, 4,800 rpm (though "1 ft/lb torque"?) ($29.95)
3) 2HP, 90vDC, 2,500 rpm ($159.99)
There are others in that ballpark, but those are the top three that seemed, with my limited information, to fit my application. (Stock mill motor was 1.5hp 1750rpm with a max of 1100 rpm at the spindle, I'd like to see closer to 2500 to 3K rpm spindle speed.)
And with one of the above motors (or other, I'm still open to suggestions) they also have these DC speed controllers:
A) Up to 2HP at 180vDC (with optional heat sink. Also has optional braking/reversing switch, fuses, etc.)
B) Up to 180vDC at 10 amp (Less info on this one, not as complete as above.)
I think I would like to go with (1) and (A), which seems like a nice matched set. I have 240vAC available, and with a 1:1 drive I'd have 3K rpm at the spindle (hopefully.)
Prices seem fairly reasonable, and even with the extra heat sink and reverse switches, is still less than a 3/ph and a quality VFD.
So, will this work? Anything I'm overlooking? The mill will be pure CNC (manual work will be done on the larger mill) and used almost exclusively for aluminum.
