I wanted to make a small (0.312" or 8mm) shaft (I'll call it a pivot) that will hold a ball bearing and have flats on each end that will fit into 0.250" slots to keep the parts to which it is mounted from rotating. There will be a #10-24 bolt through a 0.203" hole through the pivot that will hold the parts together. Here is how I made it, but there might be better ways.
First I cut a 0.65" piece of SS shaft from a scrap printer. On the lathe, I faced the ends to the desired length of 0.625". Then I used a center drill to make a starter hole, and followed it through with a 0.203" (13/64") drill. It appeared to be concentric, and does not need to be high precision.
Next, I clamped the piece in the milling vise, using a partially drilled (mistake) portion of one of the faces to hold the part about halfway exposed, and I had marked a spot 0.25" from the end for the one set of flats. I used a 1/2" end mill and adjusted the ram so that the end of the mill met the 0.25" mark, and I adjusted the cross-slide (Y axis) so that the cutter just touched the part. Then I moved the table by 0.030 to take the first cut, and then I reversed the process and took a couple of cuts on the far side to get the desired 0.250 across the flats:
Then I turned the part over, and clamped it in the flat portion of the vise jaws on the flats of the part, and this time took only a 0.125" cut for the flats. Here is the result, and it looks like it is "good enough", and maybe can be touched up a little with a small file. It has always been difficult for me to figure out how to get an accurate depth for milling (Z-axis) because the only adjustments are the ram (which has a very rough depth gauge), and the table height (which is a very coarse rack and gear crank on the column). Here is the manual for the machine so you can see what I have to work with:
http://images.harborfreight.com/manu...2999/42976.pdf
Here is the part. Definitely just "run of the mill" ! [insert smiley here]
Any reasonable suggestions and constructive criticism welcomed. I want to be able to do things like this the "right way", given the limitations of the equipment I have. And possibly ideas of ways to achieve a more accurate way to set the milling depth. TIA.
[edit] I discovered one problem. The hole is somewhat oval, 0.209 x 0.198 on one end, and 0.217 x 0.219 on the other. And so the bore is somewhat conical as well. It's not really critical, but it would be good to know how to avoid the problem. Perhaps by milling the flats first, and then drilling? And of course a reamer would be better than a drill to make the hole truly cylindrical. I have a second part to make. Let me see if I can do better!
