I have not done a lot of milling on my Harbor Freight 42976 milling/drilling machine, and when I have, it is quite noisy. I am running at 400 RPM, which might be somewhat low for a 1/2" four flute end mill. It's about 52 SFM, while it should be more like 220. But I think it has mostly to do with the lack of rigidity of the machine, and also because of the rather long distance from the spindle to the end of the mill (almost 5"). I was using it this time to mill a tool holder for my lathe, basically a 5/16" x 5/16" notch in 1/2" square mild steel, for tooling of the same size, rather than using shims:
Here is a video of my experience:
I think the end mill is OK. It feels pretty sharp, and there is only one small chip on a cutting edge:
