Dead Centers
  • Dead Centers
    I need a straight shanked dead center either 60 degree or 45 degree. The hsnak can be 1/2 inch or larger.
    Normally I would make one, but I need one to check some alignments and if I cut one and my machines are not aligned, the dead center will have the misalignment
    Any one know where I get one?
    Jerry
    If you make your own where could the misalignment be even if your lathe is misaligned? You would only be using the headstock to make it, not the headstock and tailstock.
    I guess I'm missing something.
      Jerry,
      If you make one it will be as accurate as the shaft is centered in the chuck. If you dial it in with a four jaw you should be able to get it better than .001. Is that not good enough?
        let me look in my box and see what I have.
          If you make it, mark it's orientation in the chuck. It should repeat quite well. Anything I make like this ends up getting a slight indent where the chuck jaws bear against it, giving me the 'locating' marks to use when rechucking it to the exact same orientation each time. I'm always very careful when remounting the chuck, and the runout is consistent and repeatable, so the process works for me.
            Found it. Its a CT00. Somma sells them. It a half inch in diameter with a 60 deg point. let me know and it's yours.
              One of the best way of aligning your head stock and your tail stock is to use two dead centers, one for each end. Ehen you get the points touch, tip to tip, then you can start to use finer instruments for the slight adjustments.
              This is the way many have told me to set my lathe up. If it works for them, then it must be worth doing.
              Jerry
                Rusty,
                I tried to email you and the email bounced. Please contact me when ever you can.
                Jerry
                  email sent
