Dust collector
  • Dust collector
    Sometime back a post was on here (I think) of plans for making a dust collector out of a five gallon bucket I need one for a wood lathe. does anyone remember? I don't know if it was this site or another, old age seems to be catching up.
    Not sure if this is what your looking for, but heres acouple links i have saved for myself.
    Started off: http://www.jpthien.com/cy.htm
    http://www.instructables.com/id/Diy-...bits-and-a-bu/
    http://www.woodworkingtalk.com/f32/f...-deputy-27235/
    _
      If you're willing to spend the money rather than the time, I would recommend the Dust Deputy: http://www.oneida-air.com/category.a...-B5C357DFE131}
      I have three at work on 5 gallon pails, on a table saw, band saw, and panel saw (no central system ). I have one at home on a 25 gallon fiber barrel. But, I'm not sure how well the small ones would work on a wood lathe. You might need one with a higher air flow volume to catch the flying chips.
      Ken
        I guess it will depend upon how much turning you do but with wood a 5 gallon bucket will fill up pretty quick. My dad's wood shop uses a Grizzly duct collections system attached to his table saw, planer and joiner and it fills a 55 gallon garbage barrel pretty quickly with wood chips. It may be worth looking into something bigger for both air volume and capacity.
          Ohh... i missed the word 'lathe'.
          If you have not done alot of lathe woodworking, you might be in for a surprise in the amount of chips it can create (and the direction they fly)... myself, i used to use a shovel and garbage bag, then i boxed off a corner of the basement and dont bother cleaning... makes for a nice soft floor to stand on. When sanding i use a homemade trash can collector and shop-vac (my real dust collector is too far away) like posted in the links above, but for anything else theres just too many chips to be cleaning.
            _
            Those are exactly what I was looking for, I turn pens and small bowls so I don't need a huge system don't have room for it anyway. This will help a lot thanks. I googled last night for a while and missed all those.
              I am with KMoffet.....The Dust Deputy works awesome for me on my sandblaster (NO dust)......It works so well I am going to build (2) doghouses to enclose vacuums with the cyclones for outside of my house. Then ridged pvc pipe to the side of the house----then a gate valve to flexible pipe to use on my pellet stoves for clean outs!!!
              www.neufellmachining.com
                I have one for my wood shop- works a treat. With a big Ridgid vacuum, it will keep up with the sawdust from a 6" jointer. The sawdust compacts in the bucket- it holds a lot more than you would think.
                Disclaimer: my nephew is an engineer at Oneida Air Systems. But I'd own one if he didn't.
