Wohlhaupter UPA2 Arbor Conversion?
  • Wohlhaupter UPA2 Arbor Conversion?
    Anybody know how to remove the tang from a Wohlhaupter UPA2 boring head?
    The arbor is tanged MT2 and I would like to convert it to a threaded MT2 arbor. I've heard that the tang can be removed if a dowel pin is punched out of the arbor. My arbor has a dowel pin in a hole that is cross drilled through arbor. The pin has been removedbut I can't see any way to remove the tang, which looks like it's integral to the arbor.
    Sure would appreciate a pointer from anyone that is familiar with these.
    Mike Henry near Chicago
