New throttle bodies for my car
  • New throttle bodies for my car
    Some of you may recall on my '32 Ford hot rod, I have an 8 stack fuel injection system. Meaning I have an individual throttle body per cylinder. Well, I used a TWM throttle body in originally, but always wanted to make my own, so this winter, I started on that path.
    The following pictures describe the process. The setup was designed in ProE.
    I hope you enjoy. I'll answer any questions you may have.
    Starting with raw parts, fixtures and finished comonents.
    Thanks, Sid
    Made 17 raw bodies.
    continuing:
      Injector pocket:
      Base fixture:
            cross shaft:
                A lot of other work went into these, but I didn't photo everything. Spring was coming and I had to get going!
                  As always, stunning work! The fourth picture;what am I looking at? Appears to be a boring bar with spring?
                    Wow Sid,, great piece of work, real nice, and great photos.
                      Yes- A boring bar. I had a little chatter in the bore, so an old trick, wrap the shaft in soldering lead. The lead dampens the vibration of the bar, resulting in a
                      smooth bore.
                      Sid
                        Thanks, Sasquatch!
                          Oh, yea. Here is a picture of the jaw I made to hold the bodies for various setups.
                            Beautiful work. And a nice looking machine. What is it that I"m just seeing a bit of the head in on post #4 last photo? KT rotary head?
                              The mill is a prototrak k3. I program at the machine or use cambam if I need to.
