Can I throw out one my question: I've got the lathe installed, and it basically says to lubricate the ways with Vactra 2, but use ISO32 oil in the ball oilers, including the two on the apron that look like they really lube the ways. Also the lead screw/feed rod oil points don't apear to accept a whole drop of oil- I'm wondering if there is a problem. Are we using ISO 32 oil because vactra is too thick without a pump?
BTW if there is a 4003 owner- I find the following oil points on my lathe:
3 on tail stock
1 on carrage (apron?) feed
2 on lead/feed screws.
3 on compound
3 on cross slide
2 on carrage/way contact points
This is 14, the manual says there are 15 points. Am I missing one?
Thanks guys
3 on tail stock
3 on compound
3 on cross slide
Thanks guys
