What can I do with two 250-gallon propane tank cylinders (end caps removed) ?
  • What can I do with two 250-gallon propane tank cylinders (end caps removed) ?
    They're 30" in diameter and 70" long with 1/4" wall thickness. The ends are cut flat but a little grinding here and there wouldn't hurt. Looking for ideas.
    Weld plate to the ends and turn them into barbeques/smokers?
      Add axles and drive gears, seal the ends, fill with water or sand, and make a heavy duty power roller (steam roller?)
      USA Maryland 21030
        Weld them into a 140 inch long tube, stand on end and cast into a concrete base. Have two pipes cast into the bottom also- one will terminate at the bottom, the other will have a pipe section rising up the inside to perhaps 8 or 10 feet. Paint the inside with a good sealer, then fill with good sized round rocks, then water. Make a top for it and insulate the whole thing. Run water through it until it runs clear. Now you can use it as a thermal mass. You can heat water with a rooftop collector and pass it through it, and you can use that water for showers and doing dishes.
          You can make pontoons. Just like some local boys.
            Telescope...pumpkin cannon...culvert...torpedo...gate post...small pontoon boat...gun safe...climb in and be the first to survive Niagara Falls...wind chimes...locomotive boiler...Fred Flintstone car,oops he wasn't from the iron age...really big crack pipe...barbeque/smoker...scraper behind a tractor...underground missile silo
              They are a lot more fun with the ends still on them.
                Submarine.
                  They would make a nice culvert under a road.
                    Savonius Wind Turbine
                    -http://en.wikipedia.org/wiki/Savonius_wind_turbine
                      Turn them into a couple of stills, open a small bar, and retire.
                        Cut them around at 2 foot marks and sell the as camp fire ring. They go for $100 each out here in the mid west.
                          Cut the rings a bit more narrow and make heavy duty he-man hula hoops!
                          USA Maryland 21030
                            Done that.
                              Storm shelter , was mentioned in a previous post.
                              Michael
