Hi all has any one got a good assembly drawing of the spindle and quill for a Bridgeport J head, mine had noticeable runout so I replaced the bearings, I put everything back together the same way it was thinking that would be the end of the runout, I ended up with 8 thou runout, thinking I had a bent spindle I took it to be repaired when they checked the spindle they could find nothing wrong with it.I think maybe the previous owner of the machine may have put the bearings in the wrong way around or something silly like that.My Bridgeport is one made in England by Adcock-Shipley but I think everything else will be the same as the American made ones
Thanks in advance
Will Bleeker
Thanks in advance
Will Bleeker
