Brian, I've never designed or built an engine in my life, so feel free to rubbish the following thoughts!
Could you put the valves and their associated gears and cams on opposite sides of the cylinder? That way the valve head diameters could probably be bigger, and the head would be symmetrical, which might combine to give better scavenging. It would also keep the exhaust heat away from the inlet and carburettor. And the valve gears would not have to overlap, making access to each perhaps a bit easier.
And instead of tappets, as I understand the word, could you not just make each valve stem long enough to thread an adjustable cam-follower directly into into the end?
