I'm hoping someone can let me know the approximate range of down forces typically required to cut various thicknesses of low to medium carbon steel. Might be in an owner's manual for a horizontal saw? You might have your own rule of thumb? Maybe there's a spring scale sitting handy by your own saw?
Reason is, I'm adding a simple feed to my vertical (metal cutting) band saw and want to know the range I'll need to plan for. Saw goes down to 40 sfm; I'll usually have it around 80 sfm.
Thickest I'll cut is 6". Most common will be 1/2 - 3" thicknesses, with reasonably sharp blades, and minimum of 3 teeth in the cut.
Would much appreciate any help. Not much luck after a couple days on the other boards and a good guesstimate can probably save me a bunch of trial and error to get started.
