I bought a delta pid type temperature controller and had a ssr in my garage . I battle with electronic things but it seems my controller will only go up to 999 degrees celcius.However it takes a long time to get there. This oven is rated at 7 amps .Does an oven like this utilize a lot of power over 4 hours. I am trying to figure out the maths to wortk out how much it would cost to heat treat a small item .
My second dilema is that I set the oven at 780 celcius and it holds the temp accurately to about 2 degrees. It battles at anything below 180 celcius and fluctuates as much as 15 celcius above or below. But at higher temp it is very stable. However my part was a dull cherry colour. I was expecting it to be a bit brighter. It also never lost its magnetism and I understand that at that temp it should .I used my multimeter and on converting the mv to temp I get the temp 30 celcius lower than the controller reading. Any suggestions as to how I could accurately assess what temp it is at . Could I try and see if aluminium would melt and then I know if I am in the range?
I am hoping that for most hobby type heat treating of metals that 850celcius is enough. I read that it is as bad to shoot over the critical heat as it is to be under it.
