So here is the story. I have this boat, set up for a eagle fish finder which we got new back in like 1992. After being left outside for awhile the fish finder got water in it and the screen started dropping lines of LCD's or whatever they are. I then drilled two holes in the bottom oft he fish finder, drained the water, and the fish finder worked for a few years or so like it was with a few lines of lcd's missing. After awhile we found someone selling the same fish finder and bought it as a spare. Well eventually the original dropped line after line till it was unreadable and I pulled out the spare (new/used) unit. The new one worked good for a few years and then the same scenario went down. So here we are today with a near dead second fish finder and once again I purchased a third unit in like new condition off ebay for $15
ready to go on and be used.
Now my question is, should I drill the holes in the bottom of the unit ahead of time? That way what water gets in drains out right away and there would be no build up till eventual unit death. But would it also create condensation in the unit? These are supposed to be complete sealed units and were either considered water resistant or proof when new. It is just over a few years the water finds a way in somewhere. In the last two units they seemed to be "ok" after I drill the holes in them for at least a year or two but then eventually enough lines go blank that you can't read the display. I am thinking once the water gets to the electrical the first time the corrosion is already set in and it is just a matter of time before everything just corrodes and quits. I am thinking preemptively drilling the holes will keep enough water out to avoid the corrosion. But I worry about rainy days and humidity getting up threw the holes as well and destroying the unit that way.
What to do? The boat and fish finder sit outside all summer in the rain and all, winter the boat is stored inside. I never have to touch any buttons besides the power button so thought maybe I can coat the entire things with something to keep the water out or put a bag over it or something?
I don't want to have to take it off every time I leave or use the boat.
