I had good results long ago, grinding shaper tool~bits for tool~steel.
I never realy had to do mild~steel shaper work.
I got the Gemco on it's feet and all tuned up.
Put a slab of hot-rolled on it that will be the base for an anvil.
The surface I am getting with three attempts at bit grinding
does still have a tad of tare~ing in it. I have used enuff shop made tooling
that was made before I was, to know that this must have been considered
"good enuff". It's pretty common, and paralells the same results
one gets in turning with high~speed hand ground tool bits.
If any~one has good experience in shaping / planeing in mild steel
I'm open to suggestions either in general or specific.
This is a tool-grind issue. The gemco is nearly 5000 lbs.
and in great shape, so the deficiency is my bit grinding,
or I'm expecting too much and that is why V-blocks and the like
of the same vintage I am, usually look just like this.
Thanks.
Thanks.
