I am in the design stages of a "lean-to" type shelter on my deck that is going to require a 16 ft (+) clear span under the roofline (about a 10ft wide roof). This lean-to is to be a free standing shelter; not attached to the house. The back of the shelter is of no concern, it can have posts where warranted along a standard nailed/screwed 2X? beam. However, in the front, I want no obstructions.
I can find no common beam construction technique that will clear span what I want. Even 4-2X12 can span only around 12-14 ft. So I'm looking at gluelam beams like in this random link:
http://cmfac.groups.et.byu.net/tharm...am%20guide.pdf
But the more I look, the more ignorant I become. I don't know terms like "allowable moments", "moment of inertia", "modulus of Elasticity", or most of the other design terms. I simply want a built-up beam that can take a northern Indiana snow load over a 16 or so foot span. The roofing material will be something like the Ondura panel or metal, so the actual construction load on the beam(s) will not be great. I just don't want to see it come crashing to the ground when the snow flies... and if last year is any indication, it WILL definitely fly!!
So, does anyone know of a "beams for idiots" website or reference so I can design to the correct size? Also, I know that these engineered beams are vacuum laminated but, using the correct water resistant glues, can I duplicate strength on my own (home built)?
