Originally posted by radkins
View Post
yes and no, seen plenty of both, yet not due to wear of the rings but the rings getting sludged and locking up...
have also brought many an old engine (like the one in my car) that was consuming about 1 quart every 6 or 700 miles around to going about 1500 to 2000 before needing any, with a diet of good synthetic and adding rislone when it gets a quart low...
have to be careful because you can plug an oil filter real quick if the engines been on conventional oil for all it's life,,,
just too many tear downs in the past only to find that everything is in good tolerance but sludge is creating a situation that is keeping things like ring tension from happening,,, you know this when you remove a piston and the rings don't expand when you pull it out of the bore,
But I agree about half the time it's hardened valve guide seals though too...
You can't really test whilst running to find out if it's rings or valve guide seals because both will act up on deceleration - it's high manifold vacuum and will draw oil up past the rings and also draw it past valve guide seals,,,
so the way to help distinguish is to let the car sit overnight and then fire it up and watch the tailpipe,,, if it smokes allot it's valve guide seals as they will drain down, if it doesn't it's rings as gravity is in you favor there....
this test is for conventional engines --- if it's an old volkswagon or a subaru it won't work...
