I bought two 4’-2 bulb fluorescent light fixtures, about a year apart, from a local lighting outfit (no HD). They are the same brand and are identical as far as I can tell with the exception of the bulb’s K rating. The second fixture does not illuminate immediately when the switch is thrown but takes about a 2-count. It is annoying. Does anyone know why this is happening?
Weird lighting
You said that the fixtures look the same bet the ballasts may be different. The older one has a rapid or instant start ballast and the newer one may have a program start ballast which does act like you described. Only solution is to change the ballast out in the newer fixture to a instant start.
Mr fixit for the family
Chris
