I have an idea of turning a piece of O1 or W1 down to within a couple tho of size, then use a die grinder to get the final size.
I have an air die grinder that I can fairly easily mount to my QCTP. If I use a fine stone, set the compound to about 10 degrees of paralell to the ways, then feed the grinder/stone as slow as the feed rate will go, I should be able to advance the grinder at a very slight amount, then get a better finish than achievable with a tool bit.
My question is what mounted stone would be best? Aluminum oxide comes to mind first, but there are also silicone carbide stones too. I thought the SC stones were for carbide use.
Ideas? Should I use a coolant flow? That may be messy with the grinder turning so fast.
