Need advice on buying an ATLAS Lathe...
  • Need advice on buying an ATLAS Lathe...
    There are two ATLAS Lathes for sale near me; 6" ~ 40" between centers (b/c) flat bed single phase $750, and a 12" ~ 48" b/c flat bed single phase $1200. The seller will also include accessories with that price. He states that the beds are in good shape. I can go look at them today, I don't really know what to look for though. I am currently taking a machine shop class but I won't see the instructor until Friday. I was originally looking at buying the 7 X 12 from Grizzly or something similar. Any help/advice is appreciated. Thanks
    WSmac
    W,
    First, they really aren't that long. Not sure how he is measuring them, probably the bed length.
    Go here for some inspection advice, he has a nice page written up.
    http://www.mermac.com/index.html
    Also do these machines have quick change threading, this is a bit steep for change gear machines.
    Tooling is where the money comes in, if they are well tooled the money is about right.
      stay away from import 9x20.........atlas 6 in is 6x18....12 x 36 has 54 in bed ....later 12 in has the thicker & more desirable 1/2 ways ,earlier are 3/8....change gear set irf needed will run 150-180.....quick change worth more ....need the double motor pulley for all the speeds available.....stdy rest will run150 +, follower 100+ ,chucksused are 50+ ,new 125+ ,toolholders 10-20...for 1250 , it should be x/cellent,w/ q/change & well tooled ..........where are u .......i have a 12x24 loose change w/ all gears ,tight& no sign of wear, on heavy cast iron legs& cast iron pan for 750 ..sat in farm shed for 30 years...
      best wishes
      docn8as
      docn8as
