Just was milling a gearbox and realized I was cranking the head up and then down each time I changed a tool- drill chuck, end mill holder, fly cutter. Each time I had to crank the head up, make the change, then crank it back down. Getting kind of tired of having to do this, I thought why not make a sort of universal holder that would mount to the spindle, which would then take a low profile, universal type of mount. These mounts would carry a variety of tool types (one would take the drill chuck) and would slide in sideways, then be locked in place.
My spindle takes an MT3 shank, and I've made up a couple pieces of tooling that has both that shank and a flange that's machined to be a tight fit onto the end of the spindle. These tools are noticeably more rigid than any of the MT3 shank tool holders alone. For me, the universal holder would be a progression in tool holding, and it would not interfere with the use of any of my existing tooling. I realize I would have to make the holder and the inserts, then machine each insert for the tool I want it to have. This isn't much different than having a special toolpost for the lathe, with all the various tools pre-mounted in individual holders- this would simply be the mill version of the same thing.
I suppose there might be such a thing already, but I don't recall ever seeing it. I think maybe there are things like this made for larger, more expensive mills- some of the automatic tool changers look to be a step in this direction.
You could all say get a bigger and better mill, with a better type of tool holder, but that's not going to happen anytime soon here.
