I've been cutting a series of 18DP gears of different tooth counts from 24 to 135T, using standard involute cutters I have acquired from a number of different places, secondhand. All is fine except that the teeth on the 26 and 27T gear look very thin compared to the others. I used a No.4 cutter, clearly marked '18DP', and made by Summit, a well known UK brand, who unfortunately, don't seem to be in business any more. All the measurements I have taken, using a gear vernier, on the cutter and the teeth, point to this being a 16DP cutter, but its clearly marked as an 18DP cutter. Anybody else ever come across this problem?
Its not too bad with just being the 26 and 27T gears, they don't take too long to make, when I get another cutter. I'd have been a lot more annoyed if it had happened to the 127 and 135 T gears.
Richard
Richard
