Hi. Iv been rebuilding a 1980~ Yamaha MX80 dirt bike (80cc). After draining the uh, 10mL of oil out of the front forks, I noticed the oil hole that regulates dampening rate in the shock tubes was very different on the left vs right. On one it was two 1/8" holes or so (one is maybe +1/64"), and on the other is a 1/8" hole and 3/16" hole. (On both tubes, the holes are one above another and just get covered up by the tube guide when the suspension travel is at its max)
Is it normal for the front shocks to be that different in dampening? or is that just wrong and/or dangerous?
Is a 1/4" + 1/8" hole really 'soft' for a 80cc bike suspension? Its got 4" of travel if that is any help.
Should I drill out the smaller hole on the other tube to match the larger hole? (And use thicker oil if I need more dampening?)
Manual specs 10 weight oil, its a small (130lb) 80CC bike with a 210~lb rider, likely rather larger rider then was intended.
The springs are also a little different (one is an inch longer and hence has force when the suspension is topped out while the other does not) but when compressed more then an inch or so they feel about even.
I don't really have money to buy new tubes and I would rather not weld/braze them as the tube guides go over the holes and id need to sand/file it down.
