Instead of hijacking another thread, I thought I would start a new one on building a tank and filtration system for a plasma table.
My general idea for the plasma table once I get my new shop built is a 5' X 10 - 12' table with a water tray and filtration system.
I have not yet decided on whether or not to bring the fluid* up to cover the work piece as of now but I do want the water to flow through the table to carry away the dust created from cutting,
So if I go 5' X 12' table with a 3" deep fluid level, that is about 112 gallons of water to cover the table to that depth. If the pump moves 7gpm at 0psi than it would take about 16 minutes to replace the fluid in the tray.
Having a tank that holds 28 gallons would add another four minutes to that figure, so 20 minutes to completely circulate the fluid in the system.
The first step in the filtration system would be a well about 12" deep at one end of the water tray that the fluid would flow into before going over the top of the stand pipe. This would allow the gross particles to settle out before flowing into the tank. The stand pipe would be a piece 2"BIP cut to length to establish the water level. The well area would be covered with grating to prevent small parts from dropping to the bottom of it.
The stand pipe would than be plumbed to the holding tank or a dedicated magnetic filtration tank.
Inside the tank would be a series of 304 SS baffle plates with neodymium magnets attached to catch the finer dust as the water flows over them.
Than a strainer for good measure to protect the pump from any larger non magnetic particles that would get through the system.
The holding tank and the optional magnetic filtration tank would have bolt on plate tops to prevent an overflow if the bypass was accidentally left on.
The well would have a drain and bypass that would allow the fluid to be pumped to drums for storage or to a drain for disposal.
Fluid level in the tray would be handled by the standpipe.
Having a separate tank to house the magnetic plates would add to the total fluid capacity of the system increasing the time it takes for one change of the fluid.
The tanks could be mounted on a dolly to allow them to be rolled out from under the table for cleaning and maintenance.
FLUID* referred in this thread is water without chemical additives.
Dan.
Dan.
