Adages & Proverbs Applicable To The Home Shop Machinist
  • Adages & Proverbs Applicable To The Home Shop Machinist
    'If you forget everything else I tell you just remember this: You can always take it off but you can't put it back on."
    - My big brother Angelo
    "Keep your cutting tools sharp."
    - The South Bend Lathe Manual
    "And if Tubal Cain jumps off a bridge are you going to jump off a bridge too?"
    - My Mother
    "Keep thy tools and thy tools will keep thee."
    - Benjamin Franklin
    "Don't settle for being just a mechanic. Be as well-rounded in your education as you can. The best machinist I ever knew could quote Shakespeare fluently."
    - Mr. Hood (Shop teacher)
    "Bark, Bark, Bark Gerrrrrrrrrrr BARK!!!!"
    - My Australian Shepherd 'Aussie', (Informing me that I've been in the shop too long and that there are more important things in life to do, like going for a walk, and rolling in sh*t for instance.)
    EDIT:
    Others?
    Machinists always use "cutting edge technology". Always have and always will.
    If you give a machinist a piece of junk and tell him to chuck it, he might put it in the lathe and not the trash.
    USA Maryland 21030
      "Does it work? Does it fit? Good, then quit fretting over it. You ain't building a Moon Rocket!"
        "Don't strain it, Mike - use a bigger hammer."
        Jim, a motor-racing friend half a century ago...
          "If a little do a little good, a lot don't necessarily do a lot of good".
          James Trimble (High School Teacher)
          I you are having a bad day at work or in the shop, just remember, you could be a Brazilian soccer fan.
          Those people took it hard during the World Cup. Some are scarred for life.
          "Nothing a little Bondo can't fix".
          I wonder who said this first?
          Cut to size, hammer to fit.
          Gary
            You can always take it off but you can't put it back on. Then I bought a welder.
            If you have time to fix a mistake, then you have time to work carefully so you don't make them.
            "NO JOB IS SO IMPORTANT AND NO SERVICE IS SO URGENT-THAT WE CANNOT TAKE TIME TO PERFORM OUR WORK SAFELY." This motto was posted at every work location throughout the bell system. It's still true.
            Dan
              Take all the time you need and it will take less time.
                my old boss used to say "you can't screw up, if you clean up"
                san jose, ca. usa
                  Make haste not waste.
                  Michael
                    If its worth doing. Its worth doing three or four times until you get it right.
                    A tap will always break when you are under pressure to finish the job.
                    Every piece of metal is a spring.
                      The project has not officially begun until you've bled all over it. - Peter Egan
                      Tighten it up as tight as you can get it, then go another half a turn. - Gus Richard, shop teacher.
                      Definition: Racecar - a device that turns money into noise.
                        I try to learn something new every day. Sometimes it is that what I learned the day before is wrong.
                        Jim H.
                          I thought it was "Bash it to fit, paint it to match"
                            "Sit down and put a load on your mind"
                            My jr. highschool metalworking teacher to students that were not taking things as seriously as one should (they were f-ing around...)
                            Not exactly a 'home shop adage' but it was in a shop, and I did learn a few of my home-shop-skills there, so it has to count, a bit, right? maybe?
                            frank
                              Anything is easy if someone else has to do it. - Me to Boss
                              We're having more fun than a barrel of managers! - Me to Boss
                              If at first you don't succeed, get a bigger hammer! - Heard in every shop I've ever worked at.
                              Hand me one of those C clamps - I need to measure this. - Anonymous
                              Measure it with a mike, mark it with chalk, cut it with an axe. - How to do precision work
                              Hurry every chance you get. - Boss
