Dave, you should consider FAD to be around 65%to maybe 70% of the displacement they quote and you won't go far wrong with that.
I have 2 compressors, one is a cheap ALDI unit I've had for 10 years, and next to the bandsaw is the most unloved piece of equipment in the workshop (never even checked the oil....), the other one is an SIP T3/50 belt drive which is a great small compressor - quiet & reliable for the last 6 years, although I wish I had a larger tank than the 50litre one on there. It says displacement is 13cfm but FAD is only 8.5cfm.
I do use it for beadblasting and running an airblast on the CNC. When blasting it runs continously, but with the CNC it only kicks in every 4-5 minutes as I throttle it down to 2-3bar through a very small 1mm orifice.
