My Bearing Packer
  • My Bearing Packer
    I finally solved the problem of repacking shielded bearings. I can't remember how many times I've taken things apart only to find that the bearings were still good but just needed a little grease. If they are sealed then no problem, but if they are shielded then chances are the shield will be destroyed in the removal process and not reusable. I always saved my old bearings and removed the seals from them for future use on other bearings.
    So today I thought I would try something different. I made a bearing packer. I grooved the top to accept an O-ring and made a plug for the bearing bore. I clamped everything together and gave it a few pumps. It worked. Now I guess I'll have to make a couple more for various size bearings.
    JL..................
    Kind of reminds me of a tool called the greaser used by rc helicopter enthusiasts
    http://homepage.ntlworld.com/kevin.maxfield/greaser.htm
    Batt....
      Nice job and it looks like it worked good too.
        now that's a cleaver idea
          That's a neat bit of kit.
            I like it. JR
              It appears you are pumping until grease exits the outside shield. IMHO this means the total cavity of the bearing if full of grease and that's not proper. I would bet dollars to doughnuts those repacked bearings will run super hot and fling grease everywhere they can. New bearings are cheap and 'new', why not just install new ones?
              Stuart
                Yes, nice idea, but you only want 25-40% fill unless its for low speed applications. Any way to measure what you insert?
                  Great idea! And I like the screw drivers, do you have the whole set? My son is collecting those.
                    Stuart
                    Yes, your pretty much correct. I stop at the first sign of the grease coming out the top side. No real way to accurately measure. Any excess will just push out. They are just motor bearings so I'm not worried.
                    As far as the screwdrivers........ yes I have the complete set, had them for 20 + years.
                    JL................
                      Besides not adding a measured amount of new grease, the old dried grease is still in there. IMHO the only way to resurrect a dry or stiff shielded bearing would be to pry/pop a shield off, wash out all old grease with solvent, air or oven dry, add a measured amount of new lube, replace shield.
                        I just use one of the two cone bearing packers from Lisle. Works on all sizes. Yours looks much nicer though
                        I clean them first, with hot Atf, solvents, ultrasonic
                        Once packed full, a short session with compressed air blows out the excess grease
                          Years ago, maybe 20 or more had a bunch of bearing used in a overhead trolley (bridge crane) that had bought at auction. The grease had dried out in most the bearings.
                          Used a method think had read in Fine Woodworking. Placed the bearing in a container of oil and applied vacuum released vacuum and repeated. The oil worked good on freeing up the dried out grease. Guess it was only good for about 20 years as bearings are starting to not roll as good as they used to be.
                            I was kind of thinking along the same lines as Gary. Why not inject a light oil first, then spin the bearing a bit and let it sit for a day or three. Then inject grease until it comes out clean. Then inject some oil again to push some of the clean grease out. At this point let the bearing sit in a can or something to allow the oil to run out.
                            Personally though, I'd be more apt to carefully pull the seals or shields and soak the bearing in solvent. I use air to blow them out, but don't allow it to spin. You can still repack them with the bearing packer- just make sure to wipe out all the excess that you can before popping the seals or shields back on.
                            I do tend to agree- just replace the bearing, but chances are good you'd get an inferior product. I've had some new ones that weren't worth buying and didn't last. I've had old ones that I cleaned and re-greased that have decades on them again.
                              How would the cone type packers, meant for tapered roller bearings without outer or inner race work on a radial ball bearing? Maybe an image of your's in use would help.
