Semi/OT AnyOne have any Tec Tig cups?
  • Semi/OT AnyOne have any Tec Tig cups?
    The bulb-shape is unique to Tec cups, there are no threads, they push onto a taper.
    The bulb shape has a stabilizing effect on the gass stream flow, like gass lenses do.
    My torch works great, but the cups are turning up less and less often.
    If you have run across any please let me know in a PM.
    If you actually have some, I'm not looking for a hand-out.
    Again plz PM
    Thanks.
    Switch to a gas lens and be amazed at the difference.
      I have a gas lense on another welder.
      CK / Weldmark series.
      The Tec is my Ruff Neck torch, very tuff, can run without water to 170 amps.
      Good in winter as my garage takes quite a while to heat up.
      Flow approaches lens flow, far better than standard cups.
        http://www.ebay.com/itm/Tec-Torch-Co...item562e346b16
        http://www.ebay.com/itm/Tec-Torch-Co...item4d02e54369
