Added some gib screws to my Atlas 10 topslide
  • Added some gib screws to my Atlas 10 topslide
    I noticed that the topslide only had 3 gib screws and that there was a small range of positions where there would be only 1 screw doing all the work.
    That didn't seem right to me so I decided to add 2 screws to the mix. First I picked up the centerline of the existing holes and their spacing:
    Using a small clamp and hex key to hold the gib in place while drilling a 0.130" diameter dimple:
    2 new holes drilled and ready for tapping:
    Continued in next post.
    Modified some 10-32 x 1" cap screws by turning the tips down to 0.080":
    Here it is with the topslide cranked all the way in (still need a jam nut for the leftmost screw):
    And the topslide cranked all the way out:
    And one last shot:
      Nice work Richr, that has to be better.
        Very nice RichR. Plus I learned something. I'd never thought of holding a screw in a die with a jam nut. Sure beats two or three nuts or even a split nut, I'm thinking. Thanks.
          I shall remember this good work
          Hobbyist: someone who makes something sound harder than it is.
          Professional: someone who cant afford to be a hobbyist.
            How are you holding the screw in the lathe chuck? Is it a die and nut?
            Puckdropper
              You can also use a 5C collet. Just insert the screw from the back side
              before you install the collet.
              -Doozer
              DZER
                Yah! That's a great how-to tip. No more need to make split nuts!
                Kevin
                More tools than sense.
                  Thanks guys. I had pulled out the die to have handy in case I buggered the threads and then realized I could just hold the screw in the die.
                  I suppose I could have done that, if I had collets for my lathe. I had considered drilling and slitting a piece of aluminum into sort of a poor mans collet, but
                  the die was quicker and easier.
