Atlas 7B square drive handle in search of
  • Atlas 7B square drive handle in search of
    Bought an Atlas 7B some time ago.
    Just realized that it did not come with a drive handle to raise and lower the bed. I may have known this when I purchased it but it didn't stick in memory.
    The shaft to be turned is 3/8 square. I could fab something up out of an old 3/8 socket and mics metal however if some suitable prefabbed handle is available at a good price....
    Did check McMaster Carr and e-pay with no luck.
    Anyone have any leads?
    On a totally different 7B tangent, my clapper pin nut is 15mm and I ran across something else on the table or cross feed that was metric. Did Atlas use some metric fasteners on these? Seems totally out of place for something made in Kalamazoo Michigan way back then.
    I use a crank that came from a jalousie window on some old house trailer.
    3/8 square drive, even has a set screw to hold it in place.
      Start off with a bit of square section steel structural tube with the square hole that suits you and using scrap or anything handy to build it up from there.
        No they were not metric in any way. They're out there you just have keep checking. You could buy a unfinished handle, drill it and broach the hole with the shaper.
        Central Ohio, USA
          If you wish to buy, MSC lists three imports priced at $25-30
          CarrLane displays these zinc plated iron crank handles.
          http://www.carrlane.com/catalog/inde...3C3B2853524A55
          JWWinco offers stainless versions
          http://www.jwwinco.com/products/sect...269/index.html
            The CarrLane CL-0-H crank handle w/ 3/8"
            square drive is listed for $15 at Amazon
            http://www.amazon.com/CL-0-H-Carr-La...productDetails
            A customer review describes this unit as a drop-on
            fit for an Atlas Shaper.
              DS that handle also adjusts stroke length, ram position, and table support
              George from Conyers Ga.
              Remember
              The early bird gets the worm, BUT it's the second mouse that gets the cheese.
                Reed Supply: http://www.essentracomponents.com/knobs-handles-grips
                  I just use a 3/8 female --> 3/8 female adapter on a ratchet. Worst case, you could use a 3/8 square socket.
                    I was just going to suggest something similar. Take a 1/2" hex key and Loctite it into a 1/2" 6 point 3/8" drive socket.
                      For the table, I use a 3/8" square socket (Craftsman) on the end of a speed wrench. For the other two adjustments I transfer the socket to a T-handle.
                      By the time one earns a degree from the school of experience, he's too old to practice. Wayne
                        That's what I use on mine.
                          Thanks for all the ideas.
                          At under $25 the amazon option looks good. I had been using a 3/8 drive extension (reversed) driven with a socket while cleaning and reassembling the shaper.
                            If you can get one grab it. I checked Carr Lane's web site and an availability check of that part number comes back discontinued.
                            Central Ohio, USA
                              Where do you get a 3/8 female --> 3/8 female adapter?
