I finished squaring up the swivels or trunnions as I believed they are called. One was out of square by .003 top to bottom in 3"
I also noticed that the surface was sort of concave, I'm not sure if that was intentional or just error in the factory machining.
The fixture in the picture on the grinder took care of all that error. But what I've found and I knew this prior to grinding that the index marks are all slightly off. Since I can't grind them out or fill them in and re-scribe so the only way to bring them in would be to grind the horizontal surface of each swivel. By aligning the marks and indicating the error I found that it would involve grinding about .018 on one side of the horizontal surface, way too much to play with to get a mark to line up. Since the fixture is graduated in increments of 1 degree I figure it should at least be more accurate than it is. Any suggestions?????
JL....................
