I'll be the first to admit that I'll probably still use carbide more often since I frequently play with rusted, welded up chunks of mystery steel that don't necessarily require perfect finish or tolerance, but I would like to spend a little more time working with hand ground HSS when time and conditions permit. A few years ago when I picked up my first old tired South Bend 9 all I had to work with was a few odd pieces of HSS. For those I did what I could for an edge with an ancient 6" bench grinder but when I bought my 12x40 import it came with several cut down 1" tools and well over 100 inserts, so I haven't really ventured back to HSS in a while.
My old bench grinder has a motor that is bigger than the wheels, so when I have to grind any odd long items it doesn't work well. The motor also pops the GFCIs frequently, so I think I'm going to look for something new and I figured while I was at it I would make sure that I was set up to grind HSS better. All my previous (poor) grinding was done with a 6" round wheel and occasionally the side of the wheel, even though I've been told that it's a no-no. I've seen pictures of the tool grinders like the Baldor and the less expensive Grizzly and out of production Harbor Freight one, but I'm thinking that even the $350 Grizzly is more than I'm willing to spend right now since what I do is mainly hobby level. I'm generally more willing to spend labor in lieu of cash on a project like this.
I assume tool grinding works better with the cup style wheels on those tool grinders so you are grinding flat and not on the radius, so I was thinking I could convert one end of a bench grinder to use this style wheel and build a better table / rest. I've never seen one of those wheels other than in pictures, but it looks like a round abrasive ring on a metal backer, so I assume I can just make an adapter plate? Does this sound feasible or is there something I'm missing?
Also, when it comes to the actual wheel what do I want? My most basic understanding is that silicon carbide (green) and diamond wheels are generally for carbide, so for HSS should I just go with aluminum oxide or do I want to head in another direction? Does anyone have a suggestion on a supplier? My experience with abrasives is that the lifespan of name brand expensive ones are often better than budget ones. has anyone had good luck with lesser cost products? And finally, would I want to go with a fine grit wheel for this?
Thanks,
Mark
Thanks,
Mark
