Picked up this sad old milling vise
  • #31
    What is a "rebate" in this sense for vise jaws? The only references I found were to get money back.
    It might be possible to mill a V-slot using an end mill and holding the work at 45 degrees, although it might be harder to center. Also with a V-slot and for 90 degree corners, it can be helpful to cut a narrow notch in the corner so that a square-edged part will sit solidly on the edges and not the corner.
    USA Maryland 21030
    • #32
      Hi Paul
      It's a shallow recess where the jaws meet. They act like a fixed set of parallels built into the jaws.
