I've got a Miller Challenger 172, 230 volt wire MIG and I love it!
In spite of what people tell you, I've welded Alum using argon gas of course, without any problems. No spool gun ($500) and no special liner. It takes practice, lots of practice to do Alum using any MIG / TIG welder, and some luck.
For the do-it-yourselfer who welds once a month or a couple times a year, flux core works fine either .030 or .035. And for someone using the welder as a hobby, a "real" flow meter with the ball will cost you more than you will spend for gas in the first 5 years you own the welder. The regulator works fine for the hobby HSM person.
If you have a really good service in your house and have true 20 amp circuits with #12 wire a 120 volt welder might work ok for you. Don't expect to weld alum or heavy metal with it.
If you have a 230 volt circuit, buy a 230 welder, works much better. B.G.
