I have an older chinese made 120 VAC capacitor start motor, 1/2 h.p., 1720 r.p.m., that I'd like to reverse the direction on. I disconnected the start capacitor and can reverse direction by hand when powered up. The schematic shows that I can change this to 220 volt, but no indication on reversing direction.
Can anyone here tell me which wires I can switch to reverse direction with the capacitor reconnected? Two black wires (one may be gray) are currently paired, as well as a red and yellow. You can see the green capacitor wire hanging out the end: I removed the centrifugal switch for my testing. The capacitor is clearly marked start capacitor.
I cannot swap ends which would probably do what I want because they made the end collars different sizes.
Thanks in advance for any suggestions.
DanL
DanL
