LeBlonde lathe info needed
  • LeBlonde lathe info needed
    I bought a LeBlond Regal last week to replace a 15 x 5 Southbend that was lost in the shop fire. I need to find all the info i can on this lathe. It has an oil leak and I'd like to get an operators and parts manual for it if I can. S/N is 4B852.
    Theres is lots available on these lathes. The 13 and 15 were similar. Where is the leak? - gearbox or carriage. They easily leak at the drain plugs. Do you know the year or can you post a pic?
    "Patriotism is the last refuge of a scoundrel"
      Are you sure the 4 is a 4? All the ones I've had started with a letter.
        The later models started with a number.
          http://neme-s.org/Shaper%20Books/LeB...Regal%20Lathe/
          Hope this is of use.
          Errol Groff
          Errol Groff
          New England Model Engineering Society
          http://neme-s.org/
          YouTube channel: http://www.youtube.com/user/GroffErrol?feature=mhee
            'nuther one:
            http://bbssystem.com/viewtopic.php?t=65
