A while back I converted my JET 12 X 36 BD lathe to DC / Variable speed drive. I was able to buy a new Baldor 3/4HP DC motor on Ebay for $90. But this was a few years ago.
Recently I wanted to convert my Wood Cutting Bandsaw to DC drive also so I could use it for cutting metal. A search for good quality DC motors was showing well over $200 for a 3/4HP unit.
But then I tried AMAZON. They sell 1/3, 1/2 and 3/4HP AMARINE motors for extremely good prices and if you are a PRIME customer, no shipping charges and you get it in two days.
I ordered a 3/4HP version on Friday morning and I had it on Saturday. Not sure how they can get something this heavy to me this fast...for free.
For a control board I went to Surplus Center and used a 90/180 VDC controller:
The motor cost $179 and the control $82. All I added was an ON/OFF switch. If you are powering a lathe you might want to add another switch for FORWARD / REVERSE.
This motor looks exactly like the BALDOR motor I have on my lathe. Same exact size and footprint.
My research has not found anything close in quality or cost. Please let me know if I'm wrong as I have a couple more machines I'm going to convert as budget allows.
BTW, I was using a Treadmill Motor on my bandsaw and it would stall on 1/8" steel or 3/4" Aluminum with a top quality bi-metal metal cutting blade. With the same blade, with the new motor, it cuts these materials and thicker like a hot knife through butter! As fast as I can push the material iot cuts it. I just cut up some 1" Aluminum like nothing. VERY pleased with this modification.
Thanks!
Thanks!
