Surplus Shed 50% off sale
  • Surplus Shed 50% off sale
    Surplus Shed has a 50% off everything sale going on now. Use discount code SS21415.
    They have these sales every 2-3 months. Here's a thread on their October sale:
    http://bbs.homeshopmachinist.net/thr...t=surplus+shed
    They have quite an assortment of items, especially lenses and gears, but also electronic items and tools. But don't get their 25mm micrometer. Even at the half-price of $7 it's not worth it, and if I say that, it's really quite bad.
    I had to machine a bit off the end of the spindle to read it properly:
    USA Maryland 21030
    Here's the link: http://www.surplusshed.com/
      Just ordered some optical flats and completely forgot about the code
        You really should consider saving up your money to buy only QUALITY tools Paul, and stop buying new tools that need adjustment/fixing. Buying 1st quality only hurts once.
          The tools I have and NEED are of sufficient quality to do the jobs at hand and planned. I should have realized that the micrometer was crappy just from the photo, but I just thought it would be good to have a metric mike to supplement my old Starrett.
          The half-inch mike is actually a toy, and is likely 70 years old, as it (and the Starrett) were my father's. But all of my micrometers (and most of my calipers) read within 0.001 or 0.002, and that's good enough for what I do, and the capability of my machines. Here is a metric mike for $9 that seems much better:
          http://www.banggood.com/0-25mm-0_01m...-p-935212.html
          or this, for $42, if I needed 0.001mm:
          It seems that there are two camps on the quality attribute, and I see points of both, but I'm firmly on the el-cheapo side of the fence. I always have been, and always will, unless I experience a radical change in brain chemistry.
          USA Maryland 21030
            Paul I won't argue against or for your philosophy on the quality of tools that you need, as only you can be the judge of that.
            Let's face it when someone asks what is the best lathe/mill/car for me, the first question that should be asked is what the intended purpose of the acquisition is.
            But back to the micrometers. You probably are aware of this point already but I'll mention it for those that read this that don't. There can be a huge difference between the resolution of a micrometer and the actual accuracy. This especially holds true of one that has seen a bit of real shop use. Just something to keep in mind when looking at the "specs" of some of these low cost tools. Claims of resolution far out number verifiable claims of accuracy.
              I did place an order, thanks for the heads up &half price code.
