Originally posted by oldtiffie
View Post
"Topologically" in this case a cylinder or cone is about the same as a flat surface, since the ideal matching surface is at all points touching it, just like flat surfaces, so the principle of marking is the same.
A cylinder would need to have the outer surface split for insertion/removal radially, or the blue won't be any good.... it will get smeared by the insertion process if done lengthwise. But a one-piece conical surface is fine, if you are careful about inserting part B into part A.
Noting the point about the difference being less than the blue thickness, you need a nice thin coating to resolve a small difference. Otherwise you get a big blur and no useful info. More or less as OH suggested would happen.
