rules are made for bending
  • rules are made for bending
    or at least I hope there are a set of such rules.
    I want to bend up some brass (primarily) for making small models and such. Usually stuff around .032" thick. I'm talking about circular bends, using a buck of some material - wood, aluminum, even steel if I wanted to make many. I would think there are charts out there to deal with this type of work.
    Anyway, replies to a thread like this usually tell you you need to bend tighter then the radius you want in the final product, which is pretty clear. Getting specifics is usually hard. I had hoped I wouldn't have to relegate such tasks to trial and error. Maybe I should practice w/mild steel ...
    any suggestions?
    I think you might like this.
    http://www.cutterod.com/cutter_zone/General/bending.pdf
    Gary
