Originally posted by lost_cause
View Post
OT - oven hood venting
No one has mentioned (or I missed it) Building Codes. They generally have something to say about this, and more often than not it's "must vent to outside". I suspect there is a reason for this..."A machinist's (WHAP!) best friend (WHAP! WHAP!) is his hammer. (WHAP!)" - Fred Tanner, foreman, Lunenburg Foundry and Engineering machine shop, circa 1979
Originally posted by vincemulhollon View Post
A remarkably low airflow seems to work wonders. What you're trying to ventilate can't be worse than a hot air gun, so I donno about suggestions for something NASA would use for a space shuttle wind tunnel, or five times the size of my HVAC ducts. Think of your clothes dryer duct, that thing handles 3000 watts of condensing steam, so unless you've got industrial cook gear like a KFC would have, something the size of a clothes dryer duct should be, and seems to be, adequate.
Who suggested to use something like NASA?
Who suggested to use something 5x the size of an HVAC duct?
A clothes dryer definitely has a fan to blow air,
but not sure how 3000 watts of steam enters the equation.
What I do know is that the fan in your clothes dryer
is a whole lot larger than the fan in a typical range hood,
and it is powered by a lot larger motor. This is very much
why dryer vents are 4" round pipe.
Range hoods having small fans and motors need a larger
exhaust pipe because they develop less static pressure.
The 3-1/4 x 10" duct is standard on most range hoods
that I have seen. Why adapt it down smaller??
What you are saying just does not make sense.
--DoozerDZER
Originally posted by mickeyf View PostNo one has mentioned (or I missed it) Building Codes. They generally have something to say about this, and more often than not it's "must vent to outside". I suspect there is a reason for this...
