1. I need to press in a small piece of brass into a hole .190" diam. and .188" thick and it needs to hold. How much should the plug be over sized??
2. I need to bend a 3/16" deep flange of .040" thick steel around a former. Can it be annealed and then bent/hammered around the former or does it need to be worked hot??
