Well I just bought one... What does everyone think about them? Any specific areas of interest with these lathes?
Here is what I do know:
The good:
The bad:
Anyways i'm really curious how people would compare my current 11" Rockwell to this new Clausing. The rockwell is an 11" and this Clausing is a 12" So they are similar in swing but are built very differently. Curious for anyone who has experience with both if they have an opinion as to pros and cons of each. All I can verify at this point is the Clausing has a slightly larger swing and weighs a couple hundred pounds more.
Also curious what people think about fixing the vari drive hydraulics etc. I have a VFD and motor setting around i can use. Would be it better to just ditch the vari and go VFD ?
Thanks
The good:
- Bed seems to be in good condition... At least better than what I currently have and is flame hardened. Very few nicks and no rust pitting etc.
- single phase
- Head stock seems tight
- Tail stock seems much much tighter than what I currently have.
- Has the clutch for starting while already under power. Kinda cool
- No broken gears in the head stock and no sign of shavings etc.
- Vari drive and hydraulics are complete
The bad:
- Has a few broken teeth in or around the quick change. nothing too major and nothing i cant braze and fix.
- The hydraulic parts are off of the vari drive but are with the machine.
- There may be a few bearings in the quick change which need to be replaced but again no big deal.
Thanks
