OT- Want recommendations for a good quality LED Headlamp...
  • #16
    Originally posted by Black_Moons View Post
    Id love to see an LED flashlight that used a single D cell. Or maybe two if it had too.
    D cell = 16AH. Yes *16*
    AA cell = 2AH. 1 D cell = 8 AA's!
    AAA cell = 1AH.
    Keep in mind that is at 1.5v, so if comparing against a lipo powered light, the lipo runs around 3.7v, or 2.4X more power per mAH.
    I have a 3 D cell LED flashlight, circa 2001. It uses 20 (5mm) leds at around 20ma. I left it in the attic once, and it was still shining a week later when I figured out where I'd left it.
    Of course, that 2 pound flashlight would be a bit much for a headlamp.
    Dan
    • #17
      Originally posted by alanganes View Post
      Interesting. What is the digital readout for on this unit? Do you have a link to info on this model?
      Here is what I found: http://www.amazon.com/gp/product/B00...=A67FFQ1POP4BF
      WI/IL border, USA
      • #18
        state of charge, time, date; ~$45 - $135; search for Cree miners lamp on eBay
        • #19
          Led lenser light on the head very good light long battery life
          • #20
            http://www.brightguy.com/find/what%5...ype%5B0%5D=AA/
            I would recommend looking at headlamps that use CR123 batteries instead. Yes, they cost a little more(they are cheaper online) but they run brighter and last longer.
            Dt
            • #21
              Dt
              CR123 Typical capacity: 1500mAH (lithium non rechargable), 700mAH (Li–ion rechargeable)
              Note thats at 3v and 3.5v respectively, so a CR123 gives 4.5WH while a AA gives 3WH, Not exactly a huge improvement
              Checking on ebay I see lithium CR123's for $2.50 each while AA's iv bought locally for $0.30 each on a good deal, but 0.50 each is pretty common if you find a bargin store.
              That said, you can likely get more peak current out of a CR123, but then I bet a D cell would still kick its ass given D cells are *16* AH for $1~ each.
              • #22
                Button cells?? I'll pass on that.
                Agreed!. A D cell headlamp would be kick ^ss for burn time, but a little heavy for a headlamp unless you revert to the old miners style that used 4 D cell in a belt battery pack.
                • #23
                  There's a Fenix on sale now:
                  http://slickdeals.net/f/7674020-feni...92506#comments
